Forum >Latest Maqueen Plus V2 IR sensors reversed
userHead James.Wells 2023-10-22 06:13:05 990 Views4 Replies
It looks like the latest run of Maqueen Plus V2 has the left and right IR sensors reversed. Since they are on the I2C bus I would assume the addresses are mixed up.
2023-10-23 05:55:01
I hope dfrobot will clarify this issue. Maybe there had been some updates with the V2.1
However, if you ever consider using an easy to code IoT Educational Robot for your class, you make and use something like this.
https://www.pcbway.com/project/shareproject/Develoop_IoT_Education_Robot.html
userHeadPic lia.ifat
2023-10-22 10:30:56
I just noticed there is a version block. So we need this for now.
userHeadPic James.Wells
2023-10-22 08:27:12
Looking at the PCB I see that my older robots are V2.0 while my 3 new robots are V2.1. Is there a way to change the GitHub extension to detect the board version and make the adjustments in the extension code?
Also the V2.1 run much faster! Different gear ratio? That is a bit chaotic in the classroom. But not as much as the sensor issue.
