New motor for Maqueen V1
One of our Maqueens drove off the table, and now a motor needs to be replaced. Are these sold separately?"
I found these motors in different voltages. What is the voltage I need.Thanks for your tip, I will order two motors and replace both.
The voltage that you should look for is the N20 motor which works in the 1.5~6V range.
I hope this information will help.
Best regards,
The motors used in Maqueen robots are N20 metal gear motors with a gear ratio of 1:150 (133rpm). Currently, we do not sell these motors separately. If you can obtain motors with the same specifications, I recommend replacing both motors. There may be variations in performance with these motors, so it is best to install motors produced in the same batch.
Best regards,
