Forum >PH Sensor random values
userHead Jimmy.Deriter 2023-11-01 14:53:23 1144 Views10 Replies
I calibrated the PH sensor with the 4.0 and 7.0 solution and Arduino Uno.  But my project will be based on Arduino UNO Wfi R4.  When I upload your code to the R4 and I have the sensor in the 4.0 solution,  the PH reads 2,3,4,5,6,7,8 and then random numbers.  Also I cannot ente into calibration. When I type ENTERPH nothing happen.  Thank you.
2023-11-14 03:47:39
You can cross-check the sensor with an Arduino UNO R3. If the problem persists, then the sensor itself has a problem. If it runs well with R3, then it's a matter of version incompatibility.
userHeadPic lia.ifat
2023-11-14 01:55:27
Can you confirm that you iclude the correct library?Because this library is not yet adapted to Arduino UNO R4, you will get a strupr error when compiling.
https://github.com/DFRobot/DFRobot_PH
This bug is currently being fixed and tested by the DFRobot R&D team.
userHeadPic Yeez_B
Jimmy.Deriter wrote:
Thank you for your help. To make sure,  I downloaded the library with the link you provided. I remove the old one, install the library pasted the following code from WIKI,  connect my board and select Arduino R4 WIFI and compile. https://wiki.dfrobot.com/PH_meter_SKU__SEN0161_
no error.
Sketch uses 52664 bytes (20%) of program storage space. Maximum is 262144 bytes.Global variables use 6932 bytes (21%) of dynamic memory, leaving 25836 bytes for local variables. Maximum is 32768 bytes.
2023-11-14 07:01:58
2023-11-12 17:33:31
Can anyone help with this PH Sensor? Is there a DFRobot forum where we can get support? Thank you
userHeadPic Jimmy.Deriter
2023-11-07 10:12:46
Hello, When can I expect support on your PH sensor?
2023-11-05 05:18:50
When DFROBOT will support Arduino R4 WIFI ?
2023-11-04 16:13:26
I tried library DFRobot_PH and DFRobot_ESP_PH_BY_GREENPONIK-master
2023-11-03 06:14:16
Hello,  This sensor is expensive. I would appreciate help to make it work correctly. Thank you.
2023-11-01 18:00:45
Could you posted which pH sensor and the library you are using? Cuz DFRobot have multiple pH sensor and each of them has slightly different in usage.
userHeadPic Yeez_B
Sure thank you.
https://wiki.dfrobot.com/Gravity__Analog_pH_Sensor_Meter_Kit_V2_SKU_SEN0161-V2
2023-11-02 03:47:01
