Forum >ESP32 using A02YYUW
ESP32 using A02YYUW
userHead Don.Warr 2023-11-02 03:32:16 1083 Views2 Replies
This works fine for interfacing an ESP32 to the A02YYUW  Ultrasonic Sensor…
//The ESP32 knows that Serial2 pins are RX=16 and TX=17
unsigned char data[4]={};
float distance;
 Serial.begin(115200);
 Serial2.begin(9600);
 delay(3000);
 Serial.println("Starting");
 if(Serial2.read()==0xff)
   data[0] = 0xff;
   for(int i=1;i<4;i++)
     data[i]=Serial2.read();
   int sum;
   sum=(data[0]+data[1]+data[2])&0x00FF;
   if(sum==data[3])
     distance=(data[1]<<8)+data[2];
     Serial.print("distance=");
     Serial.print(distance/10);
     Serial.println("cm");
 data[0] = 0x00;
 Serial2.flush();
 delay(100);
2023-11-03 06:13:24
Thanks. Did you make any circuit diagram/connection chart?
userHeadPic lia.ifat
2023-11-02 19:22:48
Good to hear that!
Thank you for sharing.
userHeadPic xingzhao.zhu
