Forum >Gravity: GNSS Module Disable Power Testing
userHead Daniel.Cru 2023-11-02 18:45:54 399 Views0 Replies
I recently bought the Gravity GNSS Module and I wanted to test the power consumption when disablePower() is passed to the device.  When the device is on, the multimeter reads 30mA on the power line.  However, when I call disablePower() the current reading jumps up to 40mA.  What could be causing this and how would you recommend accurate power readings for this module?
