Forum >DFR0850 - Ethernet and PoE Shield for Arduino - W5500 Chipset with Arduino UNO R3
TroubleshootingArduino
userHead Antoine.Patte 2023-11-05 09:06:56 1012 Views0 Replies
I have try a first basic code with a Arduino UNO R3 and also with an Arduino MEGA. It's working well on the mega, the shield is discover and I can use it.
But, the same code on a Arduino UNO R3 is not working, I receveive the message Ethernet shield was not found.
What I need to do to be able to use this shield on an Arduino UNO R3 ?
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
IPAddress ip(10, 0, 0, 177);
// You can use Ethernet.init(pin) to configure the CS pin
//Ethernet.init(10); // Most Arduino shields
//Ethernet.init(5); // MKR ETH Shield
//Ethernet.init(0); // Teensy 2.0
//Ethernet.init(20); // Teensy++ 2.0
//Ethernet.init(15); // ESP8266 with Adafruit FeatherWing Ethernet
//Ethernet.init(33); // ESP32 with Adafruit FeatherWing Ethernet
Serial.begin(9600);
Serial.println(".: Initialisation :.");
Ethernet.begin(mac, ip);
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found.");
else if (Ethernet.hardwareStatus() == EthernetW5100) {
Serial.println("W5100 Ethernet controller detected.");
else if (Ethernet.hardwareStatus() == EthernetW5200) {
Serial.println("W5200 Ethernet controller detected.");
else if (Ethernet.hardwareStatus() == EthernetW5500) {
Serial.println("W5500 Ethernet controller detected.");
auto link = Ethernet.linkStatus();
Serial.print("Link status: ");
switch (link) {
case Unknown:
Serial.println("Unknown");
break;
case LinkON:
Serial.println("ON");
break;
case LinkOFF:
Serial.println("OFF");
break;
delay(1000);
