Forum >Installing DFRobot Gravity IndustrialGrade Analog pH Sensor /Meter Pro Kit V2
General Gravity
userHead Anand.Jhaveri 2023-11-07 21:09:46 910 Views1 Replies
I have recently bought this pH sensor.
I would like to install this to measure my swimming pool pH on a continuous basis.
Please could you advise me on how to install this sensor to measure the pool water pH.
Regards,
Anand.
2023-11-08 07:37:31
You can make a setup like this with casing. The electrode should be underwater. The rest of the circuit should be on the ground or anywhere dry.
https://www.instructables.com/Swimming-Pool-Monitoring/
userHeadPic lia.ifat
