Forum >Microbit block code for MAQUEEN (Plus) incomplete according the sample codes
userHead Charbr0 2023-11-08 12:16:59 765 Views2 Replies
In the tutorial the Microbit sample blocks are much more extensive than available in the Microbit makecode extension.
Can somebody help me (us) to the right approach ?
2023-11-08 19:15:42
In the tutorials, there are sections where you can download the complete programs for each chapter.  For example, this is taken from the wiki page of the McQueen Plus :
 URL: https://wiki.dfrobot.com/SKU_MBT0021-EN_Maqueen_Plus_STEAM_Programming_Educational_Robot
Or from the Tutorial handbook:
 URL: https://dfimg.dfrobot.com/nobody/wiki/66f1eee56981e065131faba60a73a6f9.pdf
These links should lead you directly to the completed Makeblock example programs, with extensions selected and should be the same as the extension used in the tutorials. Some of which used Maqueen Plus extension and some maqueen plus V2.
You can choose to use the extension corresponding to the tutorial that you are following.
I hope that this information will help.
Best regards.
userHeadPic xingzhao.zhu
Charbr0 wrote:
Thank you xingzhao zhu
Best regardsCharbr0
2023-11-09 02:01:06
