Forum >SEN0366 ribbon cable pinout
userHead Klaus.Hoyer 2023-11-14 05:47:23 516 Views0 Replies
I would like to use the 8 pin ribbon cable instead of the 4 wires supplied with the distance sensor.
Please provide pinout for the alternate socket on the board.
I assume the cable is a 8 Pins 0.5mm Pitch FFC Flexible Ribbon Cable. Is that correct?
Thank you
