Forum >DFPlayer Mini
DFPlayer Mini
userHead MassimoBesozzi 2023-11-16 00:48:08 824 Views3 Replies
hi,
I'm using a DFPlayer Mini with a 4GB sd card with 1300 small mp3 files.
When I send the 0x12 command via serial line (MP3 tracks specified folder 0--9999), the sound is played immediately if the file is one of the first stored on the SD card, while it is played with more than 1 second delay if the file is one of the last stored
I need real-time playback because the module is used to generate sounds in pinballs and I always need a real-time response to follow the game.
I have tried several FAT32 formatted SD cards, but the problem persists.
I attach the YX5200-24SS manual which shows the commands that can be used with the chip mounted on the DFR0299
Do you have any suggestions?
thank you very much
icon YX5200-24SS micro usato du DFR0299.rar 929KB Download(0)
2023-11-18 02:21:30
Great player, but it's a little pricey for me
userHeadPic Edward.Santana
2023-11-17 23:58:14
hi,
thank you for your reply.
Yes I set volume, EQ, etc only one time, in the initialization procedure
The file name is in the form: 0001.mp3 to 1398.mp3
The files are played with increasing delay, already noticeable starting from the 0100.mp3 file
I also tried the solution of dividing the files into multiple folders, all under root, like 01\001_001.mp3, 52\016_063.mp3, where 01 and 52 are the folders that contain the files 001_001.mp3 and 016_063.mp3, but the delay remains essentially the same.
I followed the instructions in the manual I attached to the first post to the letter
Thanks for further clarification
massimo
userHeadPic MassimoBesozzi
2023-11-16 06:14:48
Make sure that your MP3 files have short and simple names. Avoid using special characters or long file names, as this can affect the file system's efficiency.
userHeadPic lia.ifat
