Arduino blocked on bus line
Hi, I'm Italian so I used the translator to write. I have a problem with this sketch. I have two Arduino Megas, one master, one slave. If I press the button on the slave, the DFPlayer plays the Mp3 file I set. If I press the button on the master with the Wire.write command. the cards are blocked can you help me on my project thanks.
// Master
#include <Wire.h>
pinMode(2, INPUT_PULLUP);
Wire.begin();
if (digitalRead(2) == LOW){
Wire.beginTransmission(2);
Wire.write("play");
Wire.endTransmission();
//Slave
#include <Wire.h>
#include <DFRobotDFPlayerMini.h>
#include <SoftwareSerial.h>
SoftwareSerial ss(10,11);
DFRobotDFPlayerMini mp3;
ss.begin(9600);
Serial.begin(9600);
Serial.println("running");
if (!mp3.begin(ss)){
Serial.println("controllo cavi");
while(true);
Serial.println("DFPlayer Mini On Line");
Wire.begin(2);
Wire.onReceive(ricevi);
mp3.volume(20);
mp3.play(1);
Serial.println("Mp3 play");
void ricevi(){
String comando = "";
while (Wire.available()){
comando += char(Wire.read());
if (comando == "play"){
mp3.play(1);
Serial.println("Mp3 play Wire");
I'm not a programmer so please understand if there are errors.
