Forum >EC and pH sensor not working with 16 bit adc module
userHead Mord 2023-11-22 00:49:16 829 Views0 Replies
Hello
I have this problem, that i tried to cheap out on the dfrobot adc module for the gravity sensors.
When i try to use my sensors (EC v2 k=1 and pH v2), the readings are always 0 for the EC and 15.45 for the pH. (and i have a temp sensor plugged in, but that shouldnt be a problem)
It acts just like if i were to plug the data wire from the sensors to the SDA pin on my Raspberry pi.
I just cant understanding what is the problem.
Picture from my setup: https://imgur.com/a/sUKwELX
