Forum >How to structure Commands to the DFR0534 Voice Player?
ArduinoGravity
userHead Andrew.Bray 2023-11-22 22:23:00 956 Views1 Replies
Hi - I'm trying to use a DFR0534 in an Arduino Nano project. Using the code example from the product's Wiki, I have the following bit of code
//Function to play a track
 void play(unsigned char Track)
 unsigned char play[6] = {0xAA,0x07,0x02,0x00,Track,Track+0xB3};
   mySerial.write(play,6);
         delay(1000);
when called with a file number inserted (prefaced by 0x) the function works correctly - for example this plays track #3.
case 3:
    play(0x03);//Play file0003
    break;
I would like to be able to increase and decrease the volume. The Wiki provides Command sentences for increasing , decreasing, and also a command specifying a Volume level (see below). However I don't know how to incorporate these command sentences into a function that I can send to the DFR0534 using the serial connection.
I've searched extensively on the internet, and even tried ChatGPT for coding suggestion, but everything seems to just quote the examples from the Wiki. Any insight or assistance would be greatly appreciated!
Volume settings(13)
Command: AA 13 01 VOL SM
Return: None
Explanation: AA 13 01 14 D2 Set volume to level 20.
Increase the volume(14)
Command: AA 14 00 BE
Return: None
Reduce the volume(15)
Command: AA 15 00 BF
Return: None
2023-11-23 01:17:31
Hi - If  anyone else comes across this thread ,  this seems to work:
void Reduce()
 unsigned char Reduce[4] = {0xAA,0x15,0x00,0xBF};
   mySerial.write(Reduce,4);
   //Reduce the volume(15) Command: AA 15 00 BF
     delay(1000);
    play(0x01);//Play file0001 as test of volume
void Increase()
 unsigned char Increase[4] = {0xAA,0x14,0x00,0xBE};
   mySerial.write(Increase,4);
   //Increase the volume(14) Command: AA 14 00 BE
     delay(1000);
userHeadPic Andrew.Bray
