Forum >DFPlayer Red LED
DFPlayer Red LED
userHead Account cancelled 2017-12-07 14:00:34 2373 Views1 Replies
Hi, I am trying to use a DFplayer module with an Arduino UNO.
I wired it up following the sample tutorial and used the sample code from here:
https://www.dfrobot.com/wiki/index.php/ ... KU:DFR0299
I had a previous DFPlayer that seems to work ok, but two of the ones I just ordered both give me a red led when it tries to run and no audio is played.
Any ideas?
Thanks!
2017-12-26 01:44:31 Have you check the wiring again? and since the LED light, it should be good, is there any noise in the speaker? userHeadPic robert.chen
