Forum >Request for PCB design Files
General PCB Services
userHead Ian.Donnelly 2023-11-29 16:33:54 1310 Views5 Replies
I am writing to kindly request the PCB design files / schematics for the `UPS HAT for Raspberry Pi 4B/3B+/3B` (SKU: `DFR0494`, P#:`1825`).
Having access to these files is crucial for my ongoing project because I need to understand what connection controls the power enable, and your assistance would be greatly appreciated. If you could provide these files at your earliest convenience, it would be immensely helpful.
Thank you in for your attention to this request. Please let me know if you require any further information or if there are any specific procedures for obtaining these files.
2024-04-04 14:12:55
[url]https://procadis.com/version/autodesk-autocad-lt-2023/[/url]
userHeadPic fertooos
2024-04-04 14:12:40
<a href=https://procadis.com/version/autodesk-autocad-lt-2023/>https://procadis.com/version/autodesk-autocad-lt-2023/</a>
2024-04-04 14:10:27
The features you’ve mentioned, such as the MAX17043 Fuel Gauge for accurate power monitoring and the Visual Battery Status with LEDs, are particularly helpful for maintaining awareness of the power levels without needing to write extra code. Autodesk AutoCAD LT 2023 https://procadis.com/version/autodesk-autocad-lt-2023/ promo code. The Efficient Power Management system is also a significant advantage, as it helps to maintain a low operational temperature, which is crucial for the longevity and reliability of both the UPS HAT and the Raspberry Pi itself.
2024-04-02 10:59:22
Steady Power Supply: The UPS HAT ensures a stable power source for your Raspberry Pi, even during power interruptions.
MAX17043 Fuel Gauge: Accurate power detection is achieved using the MAX17043 fuel gauge, providing information on power capacity and battery voltage via I2C communication.
Visual Battery Status: Five onboard LEDs visually display the battery capacity status without requiring additional programming.
Efficient Power Management: Over 90% power conversion efficiency and a non-diode design keep the shield’s temperature low even under continuous high load operation.
Compatibility: The UPS HAT is compatible with Raspberry Pi 4B, 3B+, and 3B.
2023-12-01 02:13:11
We apologize, as this product is not open source at this time. So we can't give you the schematic and PCB files.
userHeadPic Yeez_B
