Analog Water Pressure Sensor 【SEN0257】 2Types Check out how
I used 750EA sen0257 and plan to continue operating them in the future.
The problem is that there are two types of sensors.
The two have a voltage difference of 1.6 times.
I saw the post and saw that there had been a change.
https://www.dfrobot.com/forum/topic/315595
Is the current sensor 1.0mpa? Please tell me exactly when the sensor was changed.
And if I purchase a product from mouser or digikey now,
please let me know which one I will get: 1.0MPa or 1.6MPa.
Also, if there is a way to distinguish it from the current data sheet, I would like to request it.
Was there a situation that did not match the data sheet before 2023?
We have confirmed that we have changed the range of all sensors to 0~1.6mp in early 2023.
If I purchase from Digikina or Mouser, will 0~1.6Mpa be in stock?
