Forum >EMGAdvanced example on GitHub does not show how to connect the hardware
General GravityArduino
userHead Dara 2023-12-05 08:19:07 481 Views0 Replies
https://github.com/oymotion/EMGFilters/tree/master/examples/EMGAdvanced
In this example, there are two analog inputs instead of one
// Analog input pins
int SensorInputPins[] = {A0, A1};
But there is no instruction on what is being connected.
I have used the simple example and it works well. Although not on the plotter that comes with the IDE. I use the "better serial plotter" and that works well.
