Forum >SIM7600G-H and UNO R3
General Arduino
userHead Andrew.Sykut 2023-12-09 14:58:02 424 Views1 Replies
I would really appreciate your help getting a project going.
I am trying to use an Arduino UNO R3 board in conjunction with an SIM7600G-H to communicate with a cell phone. I am having a difficult time getting the SIM7600G-H to work with the UNO R3. I've seen a few resources that are using jumper cables to connect the UNO to the SIM7600G-H. Would it be possible to use it as a shield and directly place it on top of the UNO R3?
Another thing my group is running into an issue with is the power supply. We are a bit confused as to whether the USB connected to the Ardiuno would be enough to power the boards?
Lastly can you suggest some code to use for just testing whether or not the SIM7600G-H can communicate with the UNO R3?
Thank you for your help!
2023-12-10 22:05:31
which sku are you talking about, if it is tel0124,  it then should be able to use as a shield.  Check the wiki here: https://wiki.dfrobot.com/SIM7600G_H_LTE_Shield_V1.0_SKU_TEL0124
userHeadPic R2D2C3PO
