Forum >How to install Beats App on Unihiker?
userHead Chris.Rumore 2023-12-13 11:51:34 1124 Views1 Replies
Hi everyone - I have been making  this project from RaniBandi, but I am having trouble installing Beats.
Unihiker TR-808 Drum Machine
https://community.dfrobot.com/makelog-313520.html
I got all the rest installed/working, but
This is the line I am having difficulty with:
$ gem install beats
I was able to install Ruby and Beats on my Windows machine, but Its supposed to “live” on the Unihiker, right?
Thanks in advance!
2023-12-13 19:24:39
The following solution is from gpt-4-1106-preview and has been tested successfully:
Question: How do I install the Beats Drum Machine on a Unihiker device running Debian?
Answer:
To install the Beats Drum Machine on your Unihiker device, follow these steps:
1. Update your package list:
  sudo apt-get update
2. Install Ruby:
  sudo apt-get install ruby-full
  This command will install Ruby along with its additional packages such as `ruby-dev`, `rubygems-integration`, and documentation.
3. Install RubyGems:
  RubyGems is typically included with Ruby, but if you need to install it separately, you would normally use:
  sudo apt-get install rubygems
  However, in this case, it seems that RubyGems is already included with the Ruby installation.
4. Install build-essential:
  ```sh
  sudo apt-get install build-essential
  This will ensure you have the necessary compiling tools installed, which may be needed for some Ruby gems with native extensions.
5. Install the Beats gem:
  ```sh
  sudo gem install beats
  This command fetches and installs the Beats gem and its dependencies, such as `wavefile`.
6. Verify the installation:
  ```sh
  gem list beats
  Running this command should show you that the `beats` gem is now installed.
userHeadPic LL
