Forum >Need Help IoT Development with Sensor
Easy IoT How to select
userHead Nauman.Qureshi 2023-12-15 07:03:58 1019 Views0 Replies
Hi Forum:
I am working on an IoT Project to capture data from the sensors and push it to the Cloud Platform for analytics purposes. The sensors I need are:
Temperature and Humidity Sensors. BME680
Dust Sensor SEN0144
Analog Gas Sensor (MQ2)
Gravity: VEML6075 UV Sensor Module (315~375nm)
Fermion: MEMS Carbon Monoxide CO Gas Detection Sensor (Breakout, 5-5000ppm) - SEN0564
The question I have is which board I should select that will allow me to use a WiFi connectivity and push the data from these Sensors to Cloud. I am a Cloud Specialist, but I am not familiar with the Hardware or Kit Development. Any guidance on how to go about this project?
Thanks you
