Forum >mmWave board hanging sketch
userHead johnwargo 2023-12-18 10:10:07 481 Views4 Replies
I have two copies of the mmWave board and I can't make them work. When I first got them, I wired one up and got it working then wrote about it here: https://johnwargo.com/posts/2023/dfrobot-mmwave-radar/
I'm trying to wire the board into my project and now, suddenly, the code simply won't work. Here's a link to the code: https://gist.github.com/johnwargo/159f8808b4b14694b953a7e96b48cb6f
The board initializes (which takes 12 seconds), but then when the sketch makes a call to `readPresenceDetection`, the sketch hangs and nothing executes after that line of code.
I dug out my second board and wired it in and it does the same thing. I don't understand what's different here. I've now tried two different Feather boards and two different mmWave boards.
Any ideas anyone?
2024-04-12 14:27:55
@yeez_B I don't know enough about ESP32 serial ports to understand what you mean by try another serial port.
userHeadPic johnwargo
2024-04-11 22:29:10
I'm not very familiar with Adafruit's ESP32 board, but are you sure that GPIO20 can be used as a serial port? At least could not find the description in the Pinout of this board.
userHeadPic Yeez_B
Yeez_B wrote:
Maybe you could try on another Serial port
2024-04-11 23:57:14
2023-12-18 10:16:07
BTW - the board I'm using here is a Adafruit ESP32 Feather V2 which is why I'm using HardwareSerial in my sketch.
