Forum >DFR0362 current too low
I purchased a DFR0362 wireless charging kit through Digi-Key.
I connected it to a PCB with some electronic that sinks about 150mA with a charging circuit that can provide up to a 1A for a 6000mAh LiPo battery.
By using the USB power, I can see the correct current consumption but by powering it with the DFR0362 I can see maximum 750mA.
This only by keeping contact between the two coils.
If I put a transparent plastic ruler with a thickness 3mm, the current goes down to 5mA.
Can you please help me?
Thank you very much.
