Forum >Beetle BLE
Beetle BLE
userHead anonymous 2017-12-13 15:04:14 3015 Views3 Replies
Is there a motor shield to use with the BLE ? For a dc motor 12 volt with BT variable speed control and direction.
Also is there any Arduino sketch for variable speed, with 2 buttons to change direction ?
Charles Harris
2017-12-20 00:16:54 You can have a look of one of the product fire wheel, it uses Romeo BLE mini, you can get some idea about how to use this board by its wiki. https://www.dfrobot.com/product-1548.html userHeadPic robert.chen
2017-12-18 17:30:46 Hi
I have now purchased a Romeo BLE Mini which I will get in 2 weeks or so.
I would like an example script that uses the BT and motor options. The example with documents has a good tutorial using only the Arduino and not BT. BT is as per Bluno. I am a learner and would like the script using BT. I have no experience with BT.
That is I need to know for the sketch how to tell to use BT etc.
Is there a library of example scripts for Romeo BLE Mini ?
Thanks for your help and recommendation to use Romeo
Charles Harris
userHeadPic anonymous
2017-12-14 22:38:26 There is still no motor shield for Beetle BLE, but if you want motor drive, BLE and small dimension, then you can use Romeo BLE mini https://www.dfrobot.com/product-1367.html, and the wiki of the board may give you some idea about using 2 buttons to control the speed and the direction userHeadPic robert.chen
