Forum >Hello, I have DFRduino uno v4 and I have a strange error, namely access denied
General Arduino
userHead polituluser 2023-12-31 09:41:28 529 Views2 Replies
2024-01-06 23:21:45
You sure it is DFRduino Uno V4 or Arduino Uno R4?  Usually, you can plug and unplug the cable to solve the problem.  If not , try another usb port.  And if you are using Mac,  you may need to be careful about the Type-C to usb converter.  Some brand may cause uploading problem.
userHeadPic R2D2C3PO
2023-12-31 09:57:44
pls help
userHeadPic polituluser
