Forum >GPS / GPRS / GSM Module V2.0 using GPS and GPRS / GSM function together
userHead Lauren 2012-06-15 19:44:12 5252 Views2 Replies
Hello
I bought two units GPS / GPRS / GSM Module V2.0 and would like to know if you have any examples using GPS and GPRS / GSM together.
thank you
2012-07-28 17:12:34 Hi Lauren, when do you think you will be able to send us a sketch using both GPS and GPS ?
I try to send via arduino a batch sending a SMS to 1 phone number but nothing is coming. Your help would be very appreciated... thank you
Max
userHeadPic maxpat
2012-06-15 19:46:18 Hi Gustavo,
  I have a sketch for test the GPS and GPRS/GSM function together. But the sample code is not perfect. So I didn't release it now.
  But I send it to you. Hope it's helpful. And if it's possible, maybe you could help me to perfect it and I'll post your sketch to the website~.
  This test platform of this code is using a mega board(1280/2560/ADK). Cause that's much easier for me to test the module with the USB port, so I drive the module with the second TTL port on the Arduino. I have do a little comment for the code. But it's not very detail. So if any problem, please e-mail me.
Best Regards,
Lauren
userHeadPic Lauren
