Forum >Huskylens arduino example problem
hi
What is the problem with the results not being displayed on the serial monitor while running the Husky Lens Arduino example?
When SCL and SDA ports are removed, the results are output. .
Even if I change the board, the same symptom occurs.
Is the Husky lens broken?
2024-01-19 00:47:40
Youngjin.Hwang
Thanks for replay
Yesterday, I reconnected it with the new Husky Lands and confirmed that the output was working well.
I think the existing Husky Lands were broken.
2024-01-15 18:43:21
Yeez_B
This is generally a problem with the wiring of your HuskyLens to the controller.
Or you have not selected the HuskyLens communication protocol correctly.
Generally we select General Settings->Protocol Type -> Auto Detect on HuskyLens.
And connect to your I2C pins of your controller.
More HUSKYLENS ProjectsHUSKYLENS TutorialsView Arduino ProductsMore Arduino Related ProjectsArduino Tutorials
