windows "Connect" function with 7'' IPS screen.
Hi people!
I can't use the "connect" function of windows 10 to stream from my android phone when I use the IPS 7 '' screen. Report a message like "unsupported hardawe". However, when I connect a screen through HDMI, works fine.
I'm using LP 4BG / 64 with windows 10 home activated.
Can you fix this problem?
Thank you!
Thank you!
2018-10-29 11:57:23 I am getting the issue to Connect function with the Windows 10. It seems that virus issue in my system. What should I do to resolve this issue? I also try on antivirus support number for the help purpose but did not get any response. ritikdgh7
2018-10-23 20:17:00 The latest UI has become much easier to use, with the modern UI “tile format” being integrated with a virtual desktop feature in order to enhance multitasking and workability. anuragsinga6256
2018-10-22 11:48:32 The information you have provided on windows "connect" function with 7 IPS screen is really informative. If anyone has an issue in their Alienware laptop which is unable to get recovered. Just get in touch with the alienware support to get all your issues resolved. rosewilliams2223
2018-09-25 02:09:09 I have also faced the same issue in my new dfrobot laptop I have also connected to dfrobot Canada support but did not get any response yet. May I get the solution from here? beanpatricia031
2017-12-22 15:00:57 Did you use the screen mirroring function on your Andriod phone? I didn't used this before, maybe only HDMI devices has this function, have you use your PC which connect to the screen with other cable like VGA, to test if that is also possible to use the function robert.chen
