Forum >LWLP5000 diff.pressure sensor
TroubleshootingArduino
userHead Miklós.Zsolnay 2024-01-30 06:33:27 743 Views2 Replies
Hello Community !
I have a technical question regarding LWLP5000 differential pressure sensors. The sensor always reports 0 Pa when powered up and started. Even if there is pressure already applied at this time.
In a real world application (f.eg. reviewing differential pressure on an air filter) I cannot guarantee, that in the moment of startup of sensor there will be no pressure.
How to solve this ?
Thank you for any input !
M.
2024-08-10 11:03:36
It doesn't look like they actually built the support for either automatic or manual drift. You get errors compiling when you use either.
userHeadPic Bruiser
2024-01-31 02:06:03
If you uploaded sample code.
This sensor will automatically perform a calibration after being powered on. The sensor will take the current pressure difference between the two nozzles as 0pa.
I think you can use manual calibration, entering the pressure difference between the two nozzles yourself.
userHeadPic Yeez_B
