Forum >Extension for microbit for gamepad v4
How to select
userHead Sergio.Sánchez 2024-02-05 10:06:12 981 Views2 Replies
Hello!
Where can I find the extension for gamepad v4 for Make Code Microbit?
Thanks and bye!
2024-02-13 11:19:00
thank you very very much
userHeadPic Sergio.Sánchez
2024-02-07 18:53:03
Please refer to the wiki link below:
https://wiki.dfrobot.com/SKU_DFR0536_Micro_bit_Gamepad_Expansion_Board
The gamepad no longer requires any extensions, you can use the controller by reading the analog and digital value of the micro: bit pins and send the commands via radio.
This is an example program: https://makecode.microbit.org/_PtgDRughPidF
Microbit Gamepad Expansion Board
userHeadPic xingzhao.zhu
