Forum >How to Access Video Stream of Husky Lens
General HUSKYLENS
userHead Zachary.Mozel 2024-02-13 15:18:43 1059 Views1 Replies
For my project, I wish to view the feed from HuskyLens remotely. In this use case, I will not be able to train objects before launching the unit, I must be able to select objects to learn on the fly. How can I access the video feed from the HuskyLens? Whichever way is simplest, once I have the video stream in one way I can make it work for my project.
Thank you.
2024-02-20 00:50:13
Currently, the Huskylens's video feed can not be accessed, if you are using a Unihiker board (https://www.dfrobot.com/product-2691.html), Raspberry Pi, or an ESP32 S3 (https://www.dfrobot.com/product-2676.html) you can add a separate camera module to the project to stream the live feed video.
Best regards,
userHeadPic xingzhao.zhu
