Forum >TEL0157 SBAS: WAAS, EGNOS, MSAS, GAGAN
GravityTroubleshooting
userHead Alfonso.Sainz 2024-02-15 15:46:30 1218 Views4 Replies
According to its Datasheet (https://dfimg.dfrobot.com/nobody/wiki/afe407bbc2add6b9ba8a1014dbb82d26.pdf), this module, the L76, supports SBAS: WAAS, EGNOS, MSAS, GAGAN, but in its library, it is not possible to capture HDOP, VDOP, GDOP, PDOP, etc. The main issue for your customers is that you present a Datasheet of a product that is not correct, TEL0157 solders a Quectel L76K module not the L76. Both modules are completely different:
L76K: Chip: AT6558R / GNSS: GPS / GLONASS / BDS / QZSS
L76: Chip: MT333 / GNSS: GPS / GLONASS / Galileo / BDS / QZSS
If the L76K module indeed supports SBAS, you must implement dilution in your library: HDOP, VDOP, GDOP, PDOP. I kindly request you to make these modifications to align with the information you provide. Thank you.
2024-02-24 01:07:48
The chip used on the TEL0157 should be L76K not L76.
userHeadPic Yeez_B
2024-02-20 06:23:44
The L76K doesn't seem to include an L1 band for SBAS. Consequently, the library might struggle to display error settings such as HDOP, VDOP, GDOP etc.
userHeadPic Alfonso.Sainz
2024-02-17 12:58:43
maybe it would be good to submit a GitHub PR/ issue.
userHeadPic V205
2024-02-20 06:24:22
