Forum >BMX160+BMP388 Address Problem
TroubleshootingArduino
userHead Max-Luca.Steinkamp 2024-02-17 05:35:52 842 Views3 Replies
im using the BMX160+BMP388 to get some data about wavemovements.
I also use an RTC DS3231 (0x68). The default address of the BMX160 ist 0x68 and I physically changed it to 0x69.
With the RTC connected, the sensor getting bad data. If i disconnect the RTC, the BMX160 is not initialising.
I think its initialising on the address 0x68. I tried to change the i2C address in the headerfile but the problem is still there.
How can I solve this problem?
Many thanks for your answers.
Best regards
Max Steinkamp
2024-02-19 03:19:19
thank you for your answer. I scanned it and this is the output (not welded):
Scanning...
I2C device found at address 0x68  !
I2C device found at address 0x76  !
done
If i weld it to change the address its:
Scanning...
I2C device found at address 0x69  !
done
So its changing but while initialising its only working for 0x68. I need to make it work with 0x69.
Much thanks
userHeadPic Max-Luca.Steinkamp
xingzhao.zhu wrote:
You can try to change this address in the DFRobot_BMX160.h file to 0x69
2024-02-19 21:32:28
2024-02-19 00:35:19
Have you tried to use an I2C scanning program to check the changed I2C address? If you are using Arduino IDE, you can try the following code.
#include <Wire.h> // Include the Wire library for I2C communication
// Setup function initializes the serial communication and I2C
 Serial.begin(9600); // Initialize serial communication with a baud rate of 9600
 Wire.begin(); // Initialize the I2C communication
 Serial.println("Start I2C address scan"); // Print a message to indicate the scan is starting
// Loop function continuously scans for I2C devices
 byte device_address; // Variable to store the I2C device address
 int nDevices; // Variable to store the number of devices found
 // Search for devices on the I2C bus
 nDevices = Wire.scan(); // Perform the scan and store the number of devices found
 // Print the number of devices found
 Serial.print("Number of devices found: ");
 Serial.println(nDevices);
 // Loop through all the devices found
 for (int i = 0; i < nDevices; i++) {
   // Get the address of the current device
   device_address = Wire.getDeviceList();
   // Print the device address
   Serial.print("Device address: ");
   Serial.print(device_address, HEX); // Print the address in hexadecimal format
   Serial.println(" (0x"); // Print a prefix to indicate hexadecimal format
 // Wait for a few seconds before scanning again
 delay(5000);
userHeadPic xingzhao.zhu
