Forum >mmWave - Human Presence Detection Sensor # SEN0395
userHead Rajasekaran 2024-02-18 07:39:09 632 Views0 Replies
Hi Team,
I recently purchased the #SEN0395 mmWave Human Presence Detection Sensor.
I attempted to configure the sensor to work independently, meaning I successfully set it up to function without any start command.
However, the sensor only operates when connected with Tx and Rx. Upon removing the Tx and Rx connections, GPIO-2 immediately ceases to function. According to the data sheet, GPIO-2 should be high when presence is detected, but this does not occur when the TTL interface connection is removed.
I have saved the configuration as per the data sheet. Is there any step I might be missing to make the sensor independent?
Best Regards,
Raja
