Forum >Use SEN0546 / cht8305 temp/humidity sensor with Pico?
userHead DJ22 2024-02-19 03:46:27 1501 Views1 Replies
I have been using SEN0546 / cht8305 temp/humidity sensor with Arduino without too much issue.
I was hoping to be able to use it with a Pico ("how hard can it be?") - but so far not able to get any traction. I am admittedly not an I2C expert by any means.
I have been able to discover/scan the sensor with a Pico in MicroPython, but after that its all a blur. Whatever I do, I only seem to get “OSError: [Errno 5] EIO”
I would massively appreciate if anyone had any pointers or advise on the topic :)
Thanks in advance!!
Datasheet: https://dfimg.dfrobot.com/nobody/wiki/4c8e1057e1c118e5c72f8ff6147575db.pdf
Wiki: https://wiki.dfrobot.com/SKU_SEN0546_I2C_Temperature_and_Humidity_Sensor_Stainless_Steel_Shell
2024-09-01 05:24:05
I stumbled across your question while searching for solutions for using this exact sensor with a Pico.
Here's the Thonny code I pulled together that got the sensor working.
The top of the code has an i2c scan and outputting the addresses located.
The binary address of mine is 64 - which is what's used in the code.
If yours is different, you can update it accordingly.
>> The biggest learning curve moment I had was converting the ‘0x00’ hex addresses into binary address ‘\x00’. I had the same EIO errors until I worked that out.
This code loops endlessly while pulling temp and humidity readings from the sensor.
I was holding the sensor in my hands, breathing on it to get the humidity and temperature to spike.
##########THONNY SCRIPT###########
def calcTempFromBinary(binary):
   int_val = int.from_bytes(binary, "big")
   tempCalc = 165 * (int_val / (2**16-1)) - 40
   return tempCalc
def calcHumidityFromBinary(binary):
   humidityCalc = 100 * (int_val / (2**16-1))
   return humidityCalc
import machine
import time
sda=machine.Pin(16)
scl=machine.Pin(17)
i2c=machine.I2C(0,sda=sda, scl=scl, freq=400000)
#i2c=machine.I2C(0,sda=sda, scl=scl)
print('Scan i2c bus...')
devices = i2c.scan()
if len(devices) == 0:
   print("No i2c device !")
else:
   print('i2c devices found:',len(devices))
for device in devices:
   print("Decimal address: ",device," | Hexa address: ",hex(device))
addrDecimal = 64
while True:
   time.sleep(5)         #sleep 5 seconds
   i2c.writeto(addrDecimal, '\x00')     #request temperature read
   time.sleep(0.3)         #delay to allow temperature read
   tempBinary = i2c.readfrom(addrDecimal, 2)   #read bits from i2c
   temp = calcTempFromBinary(tempBinary)   #pass temperature binary to function for converstion
   i2c.writeto(addrDecimal, '\x01')    #request humidity read
   time.sleep(0.3)         #delay to allow humidity read
   humidity = calcHumidityFromBinary(tempBinary) #pass humidity binary to function for conversion
   print(f'Temperature is:{temp}  Humidity is:{humidity}')
______________________________
userHeadPic Ventheris
