Forum >GP8413 2-Channel 15-bit I2C to 0-5V/10V DAC Module
TroubleshootingGravity
userHead Mohit.Singh 2024-02-20 02:54:44 1397 Views0 Replies
I am using Arduino UNO and LabView to control ‘GP8413 2-Channel 15-bit I2C to 0-5V/10V DAC Module’.
a. I can control the voltage range by sending 0x77 or 0x55 to register 1.
Two byte (unsigned 8 bit integer)
1. Register - 0x1
2. Data- 0x77 or 0x55 (10V and 5V respectively)
b. I can change the voltage output by sending low and high bit of voltage to register 2.
Three byte (unsigned 8 bit integer)
1. Register - 0x2
2. Data- Low byte
3. Data - High byte
c. How to change the channel of output voltage?
Which hexagonal byte should I choose to select the channel?
Where should I place that byte in code? Whcih register?
