Forum >Facing problem with DFRobot Gravity: Active Isolated RS485 to UART Signal Adapter Module
userHead Prabhu.Singh 2024-02-21 04:21:51 941 Views1 Replies
Currently, I am using the DFRobot Gravity: Active Isolated RS485 to UART Signal Adapter Module that supports 3.3V/5V Logic Level. I am using this module teensy 4.1 https://www.pjrc.com/teensy/techspecs.html for BMS data acquisition and this teensy board supports 3.3V logic Level. Still, when I use this module with the NANO_ESP32 module which is also 3.3V logic level, I am not getting any data, only the TX LED is blinking according to my delay time. Please someone help me with this. aWhat could be the possible reason for this?
I follow this one also but there are no useful results I get.
2024-02-21 08:47:30
I am having a similar issue with https://getnewapks.com/tenkafuma-mod-apk/.
userHeadPic dumble.dor
