Forum >Think I Might Have Bricked My Unihiker
userHead Marc.Helfman 2024-02-23 23:46:38 4056 Views5 Replies
Every so often, when you first start running a Python program in Mind+, the IDE takes several seconds to erase some memory locations on the Unihiker. On one such occasion, I accidentally hit the Stop button. Now I get an error message if I try to run a program that has code to read an analog value from a sensor connected to one of the 3 pin I/O ports on the side of the Unihiker.
2024-09-23 03:34:34
I was getting this happen at times myself. But this may explain it :)
" It means that PinPong firmware initialization failed.
Case 1: It may be that multiple programs are running at the same time. For example, a program is started in the home menu of the board, and another program is run in Mind+. Both programs use the pinpong library.
Solution: first try to press and hold the Home button for 5 seconds and release it, which will close all currently running python programs, and restart the board if an error is still reported.
Case 2: You can try to re-initialize the mcu firmware,run this code:
from pinpong.board import Board
Board().begin(1)"
from bottom of page at:
https://www.unihiker.com/wiki/Troubleshooting/Error_RuntimeError_Analog_map_retrieval_time_out_or_the_readings_from_onboard_components_all_0/
userHeadPic Tony.Walsh
2024-04-07 20:17:37
I tried the re-install of the OS on https://www.unihiker.com/wiki/burner, but after I downloaded the image file and tried to load it as in step 3, I got a message saying the the image was damaged.
userHeadPic Marc.Helfman
2024-03-20 19:08:05
This error usually means that there is a program running on the Unihiker that includes pinpong. You can try refreshing the firmware of the GD32 coprocessor, as per these instructions:
https://www.unihiker.com/wiki/faq#Error:%20RuntimeError:%20Analog%20map%20retrieval%20time%20out.%20or%20the%20readings%20from%20onboard%20components%20all%200
userHeadPic LL
2024-02-24 01:01:45
Would you post your code and your error message?
Or try to re-install the OS?
Tutorial:
userHeadPic Yeez_B
Marc.Helfman wrote:
Thanks for the quick reply. Here's the code snippet:
from pinpong.board import *
import time
Board('unihiker').begin()
adc = ADC(Pin(Pin.P21))
while True:
    value = adc.read()
    print(value)
    time.sleep(0.1)
and here's the error message:
RuntimeError: *** Analog map retrieval timed out *** Do you have Arduino connectivity and do you have the correct Firmata sketch uploaded to the board?
Thanks for OS re-install link; I'll give it a try.
2024-02-24 21:36:26
