Forum >Cheap & Small Measurement Angle
RoboticsHow to select
userHead mhenrytran 2024-02-27 10:04:36 708 Views1 Replies
Currently in search for a cheap with relatively good accuracy in <1%. Small measurement angle of less than 30 degree is a must. I'm brand new into the DFRobot platform and would love to learn more about recommendations from everybody. Thanks!
2024-02-28 18:57:55
Hello.
You can use the DFR0058 for measurements, but there is no precise data on the accuracy of the DFR0058.
If you feel that the accuracy is not enough after testing, you can use SEN0221. as an industrial grade sensor, SEN0221 can reach 0.3% accuracy. But the price will be more expensive.
DFR0058:
https://www.dfrobot.com/product-86.html
SEN0221:
https://www.dfrobot.com/product-1553.html
userHeadPic Yeez_B
