Forum >Devastator Drive Wheel Assembly
RoboticsGeneral
userHead Account cancelled 2017-12-30 11:38:57 1511 Views1 Replies
I am putting together my Devastator. The instructions that came with it say to use a C1 screw to bolt on the drive wheel but this screw is too long. I looked at the instructions on the web site and it says to use a G1 which my kit does not have.
I tried a C6 which pulls the drive wheel tight together but I believe would be too short for really use (not enough screw into the mount).
Which screw am I supposed to use to mount the drive wheel?
2018-01-03 18:32:00 What Devastator platform are you using ROB0112 or ROB0128, basically, you can use C5 or C6 to mount the wheels userHeadPic robert.chen
