Forum >Connecting Gravity Speech Synthesis Module with Micro:Bit expansion board, sensor:bit
userHead yht.yht 2024-03-03 00:09:04 539 Views4 Replies
May I know how I connect the Gravity Speech Synthesis Module with the Micro:bit expansion board, sensor:bit? And also how do I code it on makecode micro: bit (https://makecode.microbit.org/#)? Is there any extension for that module?
Please reply as soon as possible.
Thanks!
2024-03-05 05:17:33
Okay, thank you for your help.
userHeadPic yht.yht
2024-03-04 19:44:17
Thank you for your reply.
If let's say, I want it to be in micro: python, just directly use the text-to-speech extension then it works fine, right?
userHeadPic yht.yht
Yeez_B wrote:
This product does not support MicroPython in Mind+, we recommend that you use ArdunioC mode for block programming.
2024-03-04 22:05:53
2024-03-04 17:55:02
This speech module could compatible with any expansion board that lead out the I2C pins. Such as this board, you could connect it to the I2C.
VCC→3V3
GND→GND
SCL→C/R
SDA→D/T
But it does not have MakeCode extension, you could code it via the Mind+, which is also a block code IDE.
Mind+:
https://mindplus.cc/en.html
userHeadPic Yeez_B
