Forum >Library for STM32 from sensor serial 6-axis accelerometer SEN0386
userHead Nova.ardhi 2024-03-06 04:47:01 832 Views4 Replies
hello, I am having problems with the "serial 6-axis accelerometer SKU:SEN0386" sensor, namely there is no library for the STM32 board with STM32CubeIDE, is there a solution for this?
Serial 6-Axis Accelerometer for Arduino
2024-03-06 18:21:39
DFRobot officially only has libraries for Arduino.
I'm afraid you'll have to modify the ArduinoC code, or just reverse engineer it to write your own STM32 code.
userHeadPic Yeez_B
Nova.ardhi wrote:
Thank you, i'll try it later
2024-03-06 22:40:55
Yeez_B wrote:
Here is the Arduino library if you are looking for it:
https://github.com/DFRobot/DFRobot_WT61PC
2024-03-06 22:46:06
Yılmaz.Uysal wrote:
Hello, if you have prepared an STM32 sample code, can you share it? It helps us a lot.
2024-12-07 04:14:58
