Forum >Is there an object limit?
userHead EliezerD001 2024-03-06 16:08:21 681 Views1 Replies
Hi! I'm very new playing with a HuskyLens and I am making a project based around AprilTags.
Through testing, I've seen that if I “overload” the camera with more than ~8 objects, Arduino crashes. Although my project will not have this situation happen, I'm wondering just for the sake of knowing if there is a built in limit for how many objects can be detected at once?
Thank you!
2024-03-06 18:22:31
Or you can try it with the ESP32, which has a higher mains frequency and larger RAM compared to the Arduino.
userHeadPic Yeez_B
