Forum >Wind direction sensor SEN0482 with Controllino
ArduinoHow to select
userHead Morten.Koch 2024-03-08 01:55:35 856 Views1 Replies
I have a problem with getting readable words from the serialmonitor.
I want to read degrees or dircetions (North, East etc.)
The things I get is square symbols, sometimes a E or a U.
I use the code from this guide:
https://wiki.dfrobot.com/SKU_SEN0482_RS485_Wind_Direction_Transmitter_V2
Products:
- Controllino maxi - SEN0482 wind direction sensor (Modbus protocol)
Greetings
Morten
2024-03-08 19:10:28
would you post the screenshot of your serial monitor as well?
The orientation of SEN0482 should be taken from the array of Orientation values.
Also, if you are using the sample code. Please check if your serial port baud rate is 115200 or try another 485 converter?
userHeadPic Yeez_B
