Forum >Humidity sensor SEN0438
userHead user002 2024-03-11 21:49:08 757 Views7 Replies
The Humidity sensor SEN0438 is not transmitting any data to microcontroller Rx pin. The sensor connection is like this
red          -    +12V     White - B of RS485 to TTL module
Black      -    Gnd       Yellow - A of RS485 to TTL module
RS485 to TTL module connection
RO - RX and DI toTX RE and DE ns joined and set to a GPIO pin
The Code is here
     RE and DE pin high;
   USART_Transmit(0x01);
   USART_Transmit(0x03);
   USART_Transmit(0x00);
   USART_Transmit(0x02);
   USART_Transmit(0xC4);
   USART_Transmit(0x0B);
     _delay_ms(1);
   RE and DE pin high;
in =USART_Receive();
 No data is received .
2024-06-11 06:04:13
I do not think it is for underwater use. If it was fit for underwater, the manuals and descriptions would have said so.
userHeadPic lia.ifat
2024-06-11 05:00:51
Informative.
userHeadPic mikegold
2024-06-09 08:02:19
Are you using this github?
https://github.com/May-DFRobot/DFRobot/blob/master/SEN0438%20-%20EN.pdf
2024-06-05 16:42:47
I want to use it to measure water temperature, but I'm wondering if I can use it by putting it in water.
Thank you,
regards
userHeadPic Michael.Jeong
2024-03-26 23:49:42
I am having issues too with the communication.
Can someone please confirm whether the following communication specs are correct?
- 9600 baud rate- address: depends on the pulled up pins- 8N1 for data size, parity and stop bits
Thank you,
regards
userHeadPic Francesco.Stefanni
2024-03-13 21:09:30
The slave address is 1 like in figure 1 . I am using atmega32 microcontroller for reading humidity from the sensor
userHeadPic user002
2024-03-12 01:11:50
What type of controller are you using? Also can you confirm that the dial address is the same as in the code?
userHeadPic Yeez_B
