Forum >TT Motor Encoder OUTPUT?
Using the TT Motor with Encoder 2.0, the 5 Vdc Encoder output voltage exceeds the ESP32-S3 nominal 3.3 Vdc. I attempted to reduce the encoder output signal using a voltage divider consisting of a 1k and 2k Ohm divider. However, the 3 kOhm load prevented proper operation. As I don't have the actual circuit with its output drive “chip”/"device" I can't determine the cause of this failure. Certainly, a few TTL unit loads (1ma) should be possible. Is the actual circuit for the Encoder 2.0 available?
2024-03-15 17:31:39
Yeez_B
Maybe not the answer you looking for, but I think you could use a level shifter like this one:
https://www.dfrobot.com/product-2285.html
