Forum >ME007YS and A02YYUW Updated code
SuggestionsArduino
userHead ryandetzel 2024-03-17 03:46:06 3302 Views0 Replies
The example code doesn't work that well if you have other things using CPU or delays. I updated the code with no delays and this works better for my use case so figured I would share. I left it basic so it's easier to read
https://gist.github.com/ryanrdetzel/6105a605caf01a89de18e51ffcbe0de8
#include <SoftwareSerial.h>
https://wiki.dfrobot.com/_A02YYUW_Waterproof_Ultrasonic_Sensor_SKU_SEN0311#target_5
SoftwareSerial mySerial(17,16); // RX, TX
unsigned char data[4]={};
float distance;
Serial.begin(9600);
mySerial.begin(9600);
int mode = 0;
int i = 0;
// Find start byte
// Read remaining three bytes
// Rest
if (mySerial.available()) {
unsigned char byteRead = mySerial.read();
if (mode == 0 && byteRead == 0xff) {
data[i] = byteRead;
mode = 1;
i++;
// Serial.println("Found start byte");
} else if (mode == 1 && i <= 3){
// i = 1
data[i] = byteRead;
i++;
} else if (i == 4){
// validate checksum
int sum= (data[0] + data[1] + data[2]) & 0x00FF;
if (sum == data[3]) {
int distance = (data[1]<<8) + data[2];
for (int i=0;i<sizeof(data);i++){
char hexCar[2];
sprintf(hexCar, "%02X", data[i]);
Serial.print(hexCar);
Serial.print(" ,");
Serial.print(distance);
Serial.println("");
mode = 0;
i = 0;
