Forum >Comprehensive FAQ Guide for Gravity: Analog Electrochemical Carbon Dioxide Sensor [SEN0159]
userHead Yeez_B 2024-03-19 18:47:03 1482 Views0 Replies
Q1: Can I use this sensor with an ESP32
A1:  The output voltage of this sensor is 0~5V, while the ESP32 ADC pin tolerance is 3.3V. so it is not recommended to connect it to the ESP32 for use.
Q2: I am using this sensor on an Arduino, but the sensor is not giving me the normal data feedback.
A2: This sensor probe operates at 6V, we have integrated a boost circuit on the board, but this will draw a lot of current when using the sensor.
So if you are using a USB port to power the Arduino, this may often not be enough.
We recommend that you use a VIN or Barrel jack (DC2.1) to power the Arduino with 7~12V.
Q3: Strange readings on my Arduino UNO R4.
A3: Arduino UNO R4 and R3 have different ADC accuracies, so the 1024 (2^10) in the code needs to be changed to 4096 (2^12)
