Forum >Gravity: Digital Hall Sensor SEN0185 rise/fall time
What is the rise/fall time for this sensor?
I'm counting rotations of a anemometer and im maxing out at about 8 rotations per second.
Is there set the rise/fall or sensitivity?
using a FireBeetle 2 ESP32-E
will try using a larger diameter to see if that helps.
ESP32 / ESP8266 ProjectsESP32 TutorialsESP8266 TutorialsESP32 / ESP8266 ProductsView Arduino ProductsMore Arduino Related ProjectsArduino TutorialsMore Gravity ProjectsView Gravity Products
