ESP32-S3 i2c for RGB sensor
I can't get this code to work! I get no response at all when I send an “r” with carriage return. It should report back the 3 values for R, G, B, but It seems like my serial command doesn't even get sent.
this code works fine withe an esp32-e but not with the esp32-s3. what am I doing wrong?
//This code will output data to the Arduino serial monitor.
//Type commands into the Arduino serial monitor to control the EZO RGB.
#include <Wire.h> //enable I2C.
#define SDA1_Pin 1 // select ESP32 I2C pins
#define SCL1_Pin 2
#define address 112 //default I2C ID number for EZO RGB.
char computerdata[20]; //we make a 20 byte character array to hold incoming data from a pc/mac/other.
byte received_from_computer = 0; //we need to know how many characters have been received.
byte serial_event = 0; //a flag to signal when data has been rRGBeived from the pc/mac/other.
byte code = 0; //used to hold the I2C response code.
char RGB_data[32]; //we make a 32 byte character array to hold incoming data from the RGB circuit. This is the max I2C input buffer size for an Arduino
byte in_char = 0; //used as a 1 byte buffer to store inbound bytes from the RGB Circuit.
byte i = 0; //counter used for RGB_data array.
int time_ = 250; //used to change the delay needed depending on the command sent to the EZO Class RGB Circuit.
void setup() //hardware initialization.
Serial.begin(115200); //enable serial port.
Serial.println("starting comms");
Wire.begin(SDA1_Pin, SCL1_Pin); //enable I2C port. (SDA pin, SDL pin)
void serialEvent() { //this interrupt will trigger when the data coming from the serial monitor(pc/mac/other) is received.
received_from_computer = Serial.readBytesUntil(13, computerdata, 20); //we read the data sent from the serial monitor(pc/mac/other) until we see a <CR>. We also count how many characters have been received.
computerdata[received_from_computer] = 0; //stop the buffer from transmitting leftovers or garbage.
serial_event = true; //set the serial event flag.
Serial.println("there is a serial event");
void loop() { //the main loop.
if (serial_event == true) { //if a command was sent to the EZO device.
Serial.println("is true");
for (i = 0; i <= received_from_computer; i++) { //set all char to lower case, this is just so this exact sample code can recognize the "sleep" command.
computerdata[i] = tolower(computerdata[i]); //"Sleep" ≠ "sleep"
i = 0; //reset i, we will need it later
Wire.beginTransmission(address); //call the circuit by its ID number.
Wire.write(computerdata); //transmit the command that was sent through the serial port.
//Wire.endTransmission(); //end the I2C data transmission.
int result = Wire.endTransmission();
Serial.println(result);
if (result != 0) {
Serial.print("I2C transmission error: ");
// Handle error, e.g., retry
} else {
if (strcmp(computerdata, "sleep") != 0) { //if the command that has been sent is NOT the sleep command, wait the correct amount of time and request data.
//if it is the sleep command, we do nothing. Issuing a sleep command and then requesting data will wake the RGB circuit.
delay(time_); //wait the correct amount of time for the circuit to complete its instruction.
Wire.requestFrom(address, 32, 1); //call the circuit and request 32 bytes (this could be too small, but it is the max i2c buffer size for an Arduino)
code = Wire.read(); //the first byte is the response code, we read this separately.
switch (code) { //switch case based on what the response code is.
case 1: //decimal 1.
Serial.println("Success"); //means the command was successful.
break; //exits the switch case.
case 2: //decimal 2.
Serial.println("Failed"); //means the command has failed.
case 254: //decimal 254.
Serial.println("Pending"); //means the command has not yet been finished calculating.
case 255: //decimal 255.
Serial.println("No Data"); //means there is no further data to send.
while (Wire.available()) { //are there bytes to receive.
in_char = Wire.read(); //receive a byte.
RGB_data[i] = in_char; //load this byte into our array.
i += 1; //incur the counter for the array element.
if (in_char == 0) { //if we see that we have been sent a null command.
i = 0; //reset the counter i to 0.
break; //exit the while loop.
Serial.println(RGB_data); //print the data.
Serial.println(); //this just makes the output easier to read by adding an extra blank line
serial_event = false; //reset the serial event flag.
I solved the problem. the esp32-S3 does not do on serialEvent interrupts. so I took everything in the serialEvent functiovn and put it inside the loop. solution below:
while (Serial.available()) {
---- rest of code
