Forum >Learning Template exceeds the upper limit (DF2301Q Voice Module)
General Gravity
userHead Wstuck 2024-04-12 06:15:36 1243 Views4 Replies
How doe I reset or clear the memory for the user commands in the DF2301Q Voice Module?
I keep getting the “Learning Template exceeds the upper limit” error.
2025-06-14 09:20:38
buenas noches.
cordial saludos.
amigos, compre el modulo DFRoboot DF2301Q  la ultima versión la V1.1 pero no se como despertarlo , no responde a el comando “ HELLO ROBOT” . que puede estar pasando? , acaso esta nueva versión es diferente a la version V 1.0
quedo atento a sus comentarios.
alvaroj78@hotmail.com
userHeadPic Alvaro.Rodriguez
2025-02-13 18:01:35
Great Job!!I have been looking for this for quite a long dinosaur game time.
userHeadPic Kristine.Hopper
2024-04-12 07:06:37
I found out how to delete or reset the DF2301Q.
It is in the manual under the Delete Wake Words and Command Words.
1: Say "Hello Robot" or you wake command
DF Module Replies “Yes I am Here”
2: Say “I want to Delete”
DF Module Replies “Do you want to delete a learned Wake Word or Command Word?”
3: Say "Delete All"
DF Module Replies “Deleting Successful”
4: Say “Exit Deleting”
Done
Now you can start over and use the “Learning Command Words” option
userHeadPic Wstuck
pavani.banka wrote:
i need to reset everything how to do?
2024-09-29 22:29:37
